Indicators Not Working?
(In Topic #129522)
Can anybody help me with my problem!? I had the dash out yesterday to see why my instrument cluster wasnt lighting up - turned out to be no bulbs there, but after putting everything back my indicators arent working. They work when the hazard light is pushed but when indicator left/right they dont work at all. The green indicator light on the cluster is permanently lit but dull, and then when i indicate the light gets brighter but doesnt flash etc.
Any ideas?
David
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
Website Manager
lhasadreams said
It is either a blown fuse or on the hazard warning switch there are two wires connected as well as the main switch connector, forget to reconnect these gives the same symptoms.
The two wires are definitely wired back up, must be a fuse then :-/
I was having a good sift through, there were a few things that had stopped working so I was hoping it would all be solved by some judicious fuse changing.
