Indicator problem
(In Topic #123307)
Indicator problem
I too have a problem with my indicators, my hazard lights work ok but when you use the indicator stalk neither left or right indicators work?
check to make sure you have switched power at the blue/black wire on the back of your hazard switch.
I had the same issue today and it was just a burnt fuse.
you're absolutely right i had 4 wires hanging loose at the back 1 was the blue/black wire which once connected to the hazard switch resulted in working indicators. As for the other wires i downloaded the relay fuse and wiring diagrams from chudd which cleared them up aswell big up the chudd!
