indicator problem
(In Topic #72927)
indicator problem
when i move the switch the warning light comes on and thats it.
any ideas?
If so, then your Hazard switch is faulty. You can take it appart to clean it, but be careful as it is a tricky one!
If not, then you got a problem with the indicators! Check out all the bulb holders for corrosion etc and clean everything up.
My Build Thread
Are both indicators (left & right circuits) not working, or just one? - if it's only one, it might be an earth issue (in the LHS of the boot), but if neither, check the stalk-switch and wiring, as above.
ok now
And it's buggin me…
black 5 door mk1 GTD
mk1 scirocco Gli in bits
