Indicator/Parking light/beam flash faults
(In Topic #75561)
Have a host of minor problems with my inidcators and Lights,
-Indicators flash like mad:
All teh bulbs are fine, and they flash at normal speed when using hazards.
-I can no longer 'flash' my full beam, stalk only lets me turn full beam on/off.
-BOTH lamps come on on left and right 'parking light' settings. (ie not just left, or just right).
Could this all be down to the stalk? or is there common relays this all goes to?
(If I assume that its not lots of coincident wiring problems… :roll: )
Life Member
Usually a problem with the earth lead from the rocker cover . (as you look at it from the front of the car it should be rear right on the rear right thread, if not look around the engine bay as it may be dangling in there somewhere).
Your problem sounds just like mine when I changed the rocker gasket and forgot to put the earth back on. ops:
Hope that helps.
Dan
Hope that helps.
Dan
