Indicator and headlight issues
(In Topic #120143)
problem 1: The indicators on my golf wont work, when i turn on the ignition the indicator light comes on solid and very dim and the indicator stick does nothing, yet the hazards work fine?
problem 2: every light on the car works fine, bar the passenger side dipped headlight. the undipped light in the same (new) bulb works fine?
i know its probably dodgy wiring but its worth a shot asking u lot on here
thanks alot guys
thanks alot guys
ah faulty hazard switch solves the first problem
anyone got any ideas on the lights?
This trick might be worth a try for the light problem : http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=73685
there is a seperate fuse for each side of the dipped beam circuit, worth a try
