Immobiliser Delete - AHU Engine
(In Topic #145522)
Where would you rerccomend for an immo delete on an AHU ECU froma 1.9TDI 1997 passat
Its going in the mk1 and I want to integrate my clocks etc etc
Regards
I posted it Monday and got it back Wednesday
Pm me if you want details I'll dig them out
John
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
Can always rely on mk1OC.
I will try andyout first as I dont use ed38 much!
Thanks to lagger too I will give vagtronics a shout if andyout cannot do it!
regards
If I chicken out on rewiring my loom into my mk1 fusebox how much would you want to do it rubjohnny?
I have both the AHU loom and the Mk1 1.1c loom…. It will have no immo to worry about aswell….
Regards
Regards
http://www.clubgti.com/showthread.php?205887
I have looked through that thread but what am I looking for here?
http://www.clubgti.com/showthread.php?192104
see my early post for a cheap tool that when modded works for junior timer pins, and later on for the full kit. the specific one i have is discontinued but i believe similar kits are available
Thanks rubjonny. Do you have the Mk1 1.1 C 1981 wiring diagrams?
Im going to have to remind myself how to read them as it has been a long while since I looked at them
I took the old loom out last night, only 2 plugs on the fusebox!! Perfect!
Gonna remove all of the stuff I dont need and then start splicing in the new loom.
On the plus side also is the fact i had another look at the key for the TDI engine i have. The transponder was in it after all!! It was the LED that was missing!
So hopefully i have everything I need.
Is there a guide or anything on mk3 to mk1 loom conversion?
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=100988
http://www.clubgti.com/showthread.php?249714
the early fusebox is poor and cant even cope with k-jet let alone anything more complex unfortunately! the main problem apart from the fuel pump pin burning out is you have no feeds for anything, so you end up having to put jumpers everywhere
