How to wire up my cigarette lighter on 93 sportline???
(In Topic #143376)
I have a THICK RED WIRE, with connector
I have aTHICK BROWN WIRE, with connector
But then final connector appeared to have 2 thin blue wires going into it, but there was also a loose thin brown wire with them??….should that be wired up with the 2 thin blue wires???
And after that, in what order do you attach the 3 connectors to the lighter…2 of the connectors fit directly to the actual lighter, and then the 3rd fits to the illumination surround……….any help would be greatly appreciated guys :-)
Website Manager
Thick brown wire and thin brown wire need to go to earth, to be safe run the wire to the earth spades just above/right side of the fuse box.
Thick red should go to a three pin connector which is then connected to another thick red that powers the radio, which then goes to a red/grey wire which goes to the fuse box connector B pin 11.
The thin grey/blue wires should be connected to the dash lighting circuit, you should find one going to your bulb that lights up the heater sliders. In fact there will be a thin brown you can connect your thin brown to as well.
So thick red and thick brown are +ve and earth feeds to the cig lighter respectively.
Thin grey/blue and thin brown are the +ve and earth feeds respectively to the cig lighter illumination bulb.
Hope that helps !!
