How to wire Spot lights up!
(In Topic #77081)
Birmingham
The important bit to remember is putting in a fuse if you're taking the power for the lamps directly from the battery (best way) as if you don't, and a wire chaffs away on a sharp bit, or the circuit develops a fault and creates a short, you'll have a fire in your engine bay.
The other important bit to remember is not to wire the lamps directly to the main beam circuit in the car, as you'll overload it and melt the wire/blow the fuses or both. You must use a relay of some sort.
The wiring kit I used is still available from Halfords for about ?14 I think which isn't too bad really.
Mike.
1983 White cabriolet GTi
d
Birmingham
c
Birmingham
in answer to your question c11rgd, I would use a separate earth to the body or to the battery and not earth it on the same wires at the headlamps as these wires have already got equipment running on them, and also as the wires are going to be old, they will have a higher resistance so the lights will proabably be dimmer than earthing them directly to the battery or body.
Also if you got too much earthing through the one wire you will most probably melt the wire. Better to be safe and use a separate dedicated earth.
Mike.
