How to reset the MFA?
(In Topic #155108)
I have tried pulling out the 1-2 switch as I read in another post
My car has returned from the garage with the MFA screen on all 8's and all the arrows, not flashing.
Does anyone know how to reset this as the other post I read mentioned the 1-2 switch, but this hasn't worked for me?
Thanks,
Steve
1983 Golf GTI Campaign Helios Blue
Regards Volkswarren
Massbad69 said
My MFA doesn't work at all and I don't have a clue what to even start :-(
Is the display completely blank or do you stil have the time showing?
1992 Sportline Cabriolet in Red
If you not sure which fuse to pull do the following.
1. Make sure your battery is fairly well charged first.
2. Remove the the positive (+) cable from the terminal of the battery for 30 seconds (count slowly).
3. Replace cable and check.
That way you are 100% sure you are resetting the MFA!
Worked for me twice.
If that doesn't work then good luck because they can be a dozen reasons why it doesn't function!
