hot start problem
(In Topic #138698)
hot start problem
still having a hot start problem when go out for drive for about an hour or so if i stop at shops or pub etc i have to like it cool down first before
it will start again im getting stressed now need help please with auto elecy
i'am a mk1 golf nutter RHODEISAN RIDGEBACK mk1 cabbys rule and you drool
cheers jb p.m my your address mate and post code will saturday be ok ?jellybelly said
dek bring it round this weekend and i'll have a session on it
i'm sure it wont be nothing to difficult
Website Manager
Can you smell fuel when trying to restart ?
Could be:
Leaking injectors - whip them out and put in jars to test.
WUR giving an incorrect control pressure for hot start, hence a crap mixture - measure it !!
Accumulator no holding system pressure, it should hold of 25mins before pressure decay starts - measure it !!
Check valve on the end of the main pump partially blocked, which means fuel will leak back - take is out and clean it.
Fuel pump really overheating, which can lead to fuse box corrosion - look for heat damage.
Could be:
Could be:
when go to resatart there is no power going to the starter until i run a wire from the battery this wire and then it will start .i have always smelt petrol ever since had car ?
Ade it's a carb model.
I had this problem and it was the starter motor.
The heat from the exhaust manifold tends todo em in.
We had cured it for a while as there is a wire with a connector that goes funny.
I think from memory Dek has had new starter, new ingnition switch etc. It's baffled us for a good while.
It will start by hot wiring it straight from the battery so it kind of points to ignition side, probably heat related as when hot a connection expands so breaks the circuit, when cold the connection is remade.
Hope it gets sorted Dek.
hoping to go upto JB's on saturday
Hi guy's,
Did you ever get this fixed, mine has the same problem.
Golf MK1 Sportline, Golf MK2 Driver, Golf MK5 Gti, Jetta MK5 TFSi
NO STILL GOT THE PROBLEM !HAVE YOU FIXED YOURS AND WHAT IS THE PROBLEM ?
Hi
Just started to investigate my problem and looking around to see if anyone else may have possible solutions that worked.
hot start problem
Is yours a auto box I. Can start mine when its hot lol it looks like I'm nicking it . I think its to do with the starter motor been under the manifold or wiring
dek sent you a pm fella.
Hi mate thanks got it have a good look tomorrow look forward to the next meet
It's a manual box, I just bought the car so fairly new to mk1 ownership.
hot start problem
Cool welcome to. The club a lot of good people on here and you will get the help a. Mates just sent me a link to hot start problem I will have a look then send you the link mate or i will ask him to put link on this . Where you from ?
Much appreciated, I am in North London, agreed this forum is extremely resourceful
I had a hot start problem with my Rivage when I bought her it was the non return valve in the fuel pump replacement of the fuel pump cured it never happened since!! Used to drive me insane!! Hope this might help
My dad used to say I squandered money, so I made an invested in my Rivage he's still not happy - but I love my money pit!!
There are differences between GTI and Carboureted models though.
AmaZak yours a GTI or carb model.
Mine is a Gti, however my friend has convinced me to ditch the K-Jet injection completely and fit a golf mk3 setup with standalone management so I have bought mk3 engine and he is going to fit it for me, might get a few engine mods too :twisted:
Battery was faulty, fitted new battery all good now.
