Horn not working. MOT retest due monday!!
(In Topic #78007)
I thus replaced both horns and they both work using the same test.
There is a 12v voltage at the positive terminal and if I earth either horn they sound.
When I pressed the horn button I could hear the relay click, but this no longer happens.
Anyway I could just link the horn button to the actual horns? Or must I use the relay/fuse box??
If so what terminals should be going where??
Cheers in advance
This will tell you what parts faulty ! You could also try just one horn , disconnect one only then try , it may be the wiring is old and will not support both horns , if so just use one . Or build a relay near the horns .
Hope this may help ?
Chudd………
hope this helps.
Regards Volkswarren
On my GTI I found the horns to be very problematic and currently it seems to work if just ones connected. Got another winging its way to me via ebay so I will try and get both hi and low tones to work next week.
I need to know what terminal are for what on the relay, then I can check for continuity between what should be connected.
i've swapped the relay with a known good one from my golf and there is still no clicking.
Fuse Intact
Connection between horn press and terminal 85 are fine.
Ignition Off
85-blue/brown no charge
86-black no charge
87-brown negative
30-brown negative
Ignition On
86-black no charge
87-brown positive
30-brown negative
Ignition On and Horn Pressed
85-blue/brown negative
86-black negative
87-brown positive
30-brown negative
There is a 12.5v at the positive terminal of the horn, the horns are new and function properly when using a power probe.
The thing is when I press the horn press, nothing happens!! no relay click, no output.
However if I use my power probe and apply a positive voltage at terminal 86-black and then operate the horn press the horn sounds.
Can someone figure out what is wrong here?? I would have thought that the black would have had a positive rather than 87-brown???
I need to sort this by monday.
Same as me ……..The relay is too far away from the horns because the old cable is suffereing fron poor conductivity [inner black death] and voltage drop . If you were to move a relay next too the horns and use battery poz direct as a power supply the problem would be cured .
Getting back to Gareth …….You should have continuos power at term 30 fuzed to the box . You should have live at 87 when the relay is earthed ….And this earth comes via the steering collum so it must be the earth missing from somewhere . :dontknow: Are you sure you have a continous cable from the horns push to the horns them selves , and remember this is the earth needed to activate the relay , push the horn push , complete the curcuit relay clicks in horns work .
Cheers …….
(Sorry for hijacking ops: )
Cheers,
Arun
You need to do this
…………The relay is too far away from the horns because the old cable is suffereing fron poor conductivity [inner black death] and voltage drop. If you were to move a relay next too the horns and use battery poz direct as a power supply the problem would be cured ………
The buzzing is because you don't have enough zap to run the compressor .
If you have followed the 'Dim lights' on a mk1 saga you will follow what i mean . Fitting a relay for you is the only way .
Cheers………
just swap 30 and 86 round???
It should pass the MOT then.
TT
