Horn help please
(In Topic #119968)
Horn help please
Alex
There is no black wire [if wired correctly] in the standard horn wiring . The steering wheel wire is brown/black and is used simply to supply and earth to the horn relay . Not sure what you have inherited
If i wanted to rewire the horn how would i do that? starting from scratch would be good if anyone can help.
Cheers for the reply.
Alex
Alex
fit the relay too, duel horns need it to supply enough voltage.
<a> <img></a>
Life Member
Someone mentioned the steering rack should be earthed, but any idea where?
Paul
Life Member
Before you struggle with that - because it is awkward to get to, try taking you steering wheel off and setting it a couple of splines off centre and see if that helps. The copper ring wears down and doesn't make a good connection, by moving the wheel round slightly it may work - mine did about 5 years ago and still does now!
Dan
If this makes any sense!
Life Member
There will be other threads that will give more information, if you do a search it may cut your efforts down.
Dan
Managed to get the wire orr the steering column, and then run a new earth, as couldnth get the screw out of bulk head.
But all working now though!
Now to fix my clock next and change the heater blower!
thanks again.
Court
