Horn gremlins
Horn gremlins
Can anybody shed some light on this. My horn wasnt working so after fidling around with the fuse box I found that for some reason my fuse box references are in french and as I dont speak it I just checked every fuse and found number 15 (it was a 10 amp) had blown so I replaced it. Still no horn.
I then took the horn off and connected it direct to the battery, horn worked  :D
I re connected the horn back up, obviously I knew that it wasnt going to work, and it didnt. So, I connected up the black/yellow ( I believe is live) wire to the horn and ran a wire from the batt earth to the horn earth and it was constantly belting out a beep, as if the steering wheel horn was being held.
Is the horn switch connected to earth so when its pressed it makes an earth?
Because I thought it was switched live?
i'm confused to what it could be. It used to work fine, and I havnt touched the steering wheel.
Help?
Check the brown earth wire from the steering rack (down the back of the engine bay) always a problem.
In addition to the above, from a previous reply;
VW wire the horn totally differently to the rest of the world. +12v is run to the horn permanently (or at least when ign on) and the switch at the steering wheel earths to -ve.
There are relays involved (on GTIs at least) and the horns draw a lot of juice, any slightly duff connections and they won't work. I'd start be removing the horn/s and testing direct to a battery, even if this works doesn't mean that the horn will work when back under the car. Another trick is to just have one horn on the GL/GTI setup as both seem to overload the system.
Thanks. Ive fixed my horn. It was the wire on the steering rack. I had taken it off when I removed the steering rack so I could paint the engine bay and I hadnt re-fitted it. I didnt think it would be so important, lesson learnt.
Thanks for helping boys
Direct wiring
Earth on steering column
Spring connection under the steering wheel itself
Relays and fuses
FAQ Section
May help
Hi,
i also have a problem with my horn..
i have read this topic and will check everything i can..
wanted more details on where this earth is on the steering rack please?
my horn does work but very low, not loud at all (maybe one 1 of the 2 are working :dontknow:)
would mine be the same problems as mentioned or would someone know whats wrong here?
Thanks!
bump
there is a picture in this thread .. but yours should have the engine in the way!  :mrgreen:
The Mk1 Golf Owners Club
thanks for that..
would it be possible to sort it out from underneath the car if it was on a ramp?
i couldnt tell exactly where that is but seems like its the left side from looking into the bay..
