Hi again people.
(In Topic #127979)
Hi again people.
I have searched the other threads and had no joy.
Picked up my mk1 golf 1983 1.6 diesel last night and drove her home.
Was doing some work on her today and i noticed that the temp guage does not move. The red light comes
on and then goes off as normal but the temp guage does not move. I am not sure when the fan is meant to kick it but i did
not want to let the engine run to long incase of over heating.
I have shorted the fan and it runs.
My question to you all is how long should the car run before the fan kicks in and has any one any pointers as to why my guage is
not moving.
Thank you all in advance.
Temp guage not working can be a few things, but 1st thing to check is the thermistor, which i'm not sure of the location on your model but on mine is the right side of the engine, near the 4 way water housing, could possibly either be disconneted and/or corroded, and is a yellow wire, with (I think) red stripe.
Otherwise check the socket on the back of the dash.
Hope that helps.
~Madferret
Mk1 1457cc 5door GX '83
Hope that helps…
~Madferret
I have ordered a load of service stuff and have also ordered thermistor and fan switch. I will pull out the meter tomorrow and give your tip a shot.
Cheers.
Fitted temp sender (thermistor) and my temp guage now works.
Going to have to take all the stuff back and swap it over.
Today i will be removing the sump to fit a new gasket and i will do a full engine service then it's of to the garage next week to get timing belt and tensioners done. I would attempt it myself but i am not to sure as i have never done timing before and dont want to mess it up.
Post us some pics of your beauty
Cheers :wink:
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Today i will be repairing the lights in the dash binacle and fitting an alarm and cd player so will upload them later on.
