help, no indicators!!
(In Topic #81019)
my indicators have gone on the blink :?
if i select up or down on the steering column stalk the green light inbetween the speedo and rev counter that should blink just stays on constant.
when i return the stalk to the centre position (off) the green light goes off but looks like its very faintly lit :dontknow:
anyway, the indicator lights externally do not come on at all with the stalk in any position :cry:
when i put the hazards on though all lights work as normal :dontknow:
is this a kaput relay?? how much do these cost approx??
cheers for your time
TG
Need your console repaired or mods done? drop me a pm
Life Member
This happened to me once when I was pulling the dash apart and lost the springs - it took me a while to figure out! I found you can substitute a bit of folded paper for a spring if you've lost one.
Also, just as an aside, GSF don't do refunds on electrical items, so make sure you really need a new relay before you buy one…
HTH
Rich
Tian
Tian said
If it was the relay the hazards wouldn't work, would they? It's got to be the fuse.
Is the fuse for the indicators separate from the one for the hazards?
My money is still on the hazard switch
Rich
