Help! ...can't turn off me wipers!
(In Topic #111347)
I did notice a couple of drops of water on the fusecover, has been monsoon over here last few days.
Cheers, martin
Web Team
Website Manager
There are three live feeds to the motor, one to select first speed, one to select second speed and another permanent live so that the wiper has power to park when you turn it off.
The track between the first speed and the parking live had become shorted out.
I drilled the rivits out and was able to clean the short up.
You can do a simple test with a multimeter at the wiper connector to see if the volts are being removed from the 1 and 2 speeds, if they are then I would say it is the motor, otherwise it is the relay or stalks.
Hope that helps
next problem is now figuring out HOW water is getting into the fuseboard reigon at all?! Bulkhead looks good as does scuttle, can't see any nasty holes etc. wondering if theres any other not so obvious ways in…can't have water getting in else I'll have a fast (but not so nice) pile of rust shortly
