heaters arn't working.
(In Topic #133083)
8O
Quick check will be to remove the scuttle plastic panel and fan assembly cover and see if you can turn your fan by hand, if you can, get your self a length of cable and carefully touch the positive connector with you cable to the battery positive terminal. If your fan then runs you probably have a short to earth somewhere (chaffed cable maybe)?
Again be carefull, although there isn't alot of voltage in a car battery, its the currant that does you damage.
06 Audi A3 (Wifes daily)
