Heater
My in car heater was working intermittently for a while, now it doesn't switch on at all. I've checked the fuse and it seems OK. Any ideas of other things to check or what could be causing this?
Thanks,
1984 Golf 1.8 GTi Cabriolet
Bushes worn out in the motor?
Jon
Thanks Jon. What's the best way to check if it's the bushings? Take the motor out and they would be visibly worn?
Thanks,
Sorry, typo should be brushes, memory is a bit fuzzy or access to blower motor wiring, but the answer would be probably yes, because if they are worn out you will need to fit a new blower motor or at least replace the old carbon brushes if you can source and fit new ones
Ah OK, there's a blower motor removal guide on here so I will have a go, and have a look. Thanks Jon
