heater fan
(In Topic #72207)
heater fan
wots the most probable reason…could it be the switch on the dash?? fuse is ok??
my windows r streamed up and cant be driving around with the windows open coz its freeezin!
My Build Thread
My windows got extra steamy the other day!!!
Before you say any anything I better explain! The 2 drain holes in the scuttle area in front of the windscreen blocked. I check them regularly as i know its a common problem but it only took a week or two for them to block with leaves. The water that collected went through the heater air intake and blew onto the windscreen and floor! Thought my heater matrix had gone at first!
1983 1100 C
1983 1100 C
http://www.campaignreg…orum/viewtopic.php?t=1678
If you can then it's worn contacts/ brushes on the heater motor.
If not then it's got to be positive feed to the resistor. Basically There are two resistors in series,
on position one current is fed through both,
on position two current is fed through one
on position 3 they are both bypassed.
Take a look at the wiring diagram, it's really quite straightforward arrangement.
Peter.
1980 1600 GTI, daily driver.
too dark to wrk on the car after wrk now
Yeah, I hear you there.
Weekends become even more special in these winter months.
shud have one by next week hopefully it cures it!
1996 Gti Anniversary 8v Mystic Blue
1995 Gti 16v Fjord blue
so im guessing i should just get a new heater fan! damm. bet its gonna be a pig to change!
although b4 i do this….i havent tried the new resistor in conj with a fan swich that i know 100% works from my other car!
a couple of kitchen towls and a chammy withh do the trick for now :cry:
I did that to get the thing moving again, and sprayed loads of wd40 into it.
Peter.
the earth going to the rossette on the fuse box was disconected!
we have clear windows
