Heated seats
(In Topic #120325)
Heated seats
I have seen aftermarket kits on ebay that look to be good quality and I've also seen a build thread on Edition 38 with a kit fitted into Edition 1 G60 Recaro's.
Can anyone with a Rivage with heated seats post up a picture of the switch/controls. The aftermarket kits switches look fairly OE, but I'd like to see what VW supplied and where they located the switch as standard before going aftermarket.
I think it will be a nice addition to the car, allowing it to be used with the top down on these cold yet sunny days we have been having recently. My main worry is wrecking my seats!
Has anyone else considered or done this?
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
One seller had a few kits a couple of weeks back with carbon heaters and occupancy sensors but seller dissappeared after a few weeks, which is normally a bad sign.
been thinking about these
ebay heated seats
1988 1.8 carb Golf Clipper
I know what you mean about the seat material neo, mine are in good condition but I've only experienced heated seats when they are leather (usually freezing on a morning!) and don't want to ruin the seat fabric. I'd be gutted if I fitted the kits, switched them on and melted the seat!
Here's the thread I keep looking back to on Edition 38:
Recaro seat strip down
Has anyone stripped down a fabric Rivage seat? Do they have a thin foam layer between the heater element and the seat cloth?
http://forums.vwvortex.com/zerouser?cmd=viewprofile&id=297437
rubjonny said
drop this guy a pm, he lives in canada where heated seats are common as muck, so can get hold of complete VAG kits for most models. got my MK2 Golf setup from him.
Cheers!
rubjonny said
if you want to know what MK1 switches look like, open your owners manual
Good call :doh:
the pads are pretty easy to repair, bit of solder and some wire does the trick usually
Cheers, Bob.
That is all.
Life in the French Alps: <a href="Le Franco Phoney: All things French in La Clusaz, Annecy and Haute Savoie">www.lefrancophoney.com</a>
It lives under the carpet within the frame in a bit of sponge under the seat as in the diagram above.. This is the cause of my passenger seat not working. my passenger side used to leak badly from the cabby handles and through the bulk head
found this link about heated seats which I think is useful, but I havent checked the wire colours match.
http://forums.tdiclub.com/showthread.php?t=154510
new…… and old
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
jayjay31 said
i think this is whats wrong with mine as my seats dont heat
i have a rivage and in preston if you want to come over and try and figure out whats wrong with yours.. if they both dont work i would expect its the elements..
cheers tony
