Headlight switch question
(In Topic #79346)
Just sorting out some electrical gremlins on the Caddy, and have most of them fixed now. However, I have a question about the headlight switch
Basically the light for the switch is on all the time when ignition is on (ie, switch illuminated all the time). Is this right ? I would have thought it should only come on when the lights are turned on ?
Previous owner had taken bulb out (!)
Caddy is a '92 - same electrics as a late Cabrio
Oh, and I have a bulb hanging by the wires not going anywhere that flashes when the hazard lights are on. This is in addition to the bulb in the hazard light switch. Any ideas where this should go ?
I could bypass the problems with a bit of rewiring, but would rather solve them 'properly' rather than mask over them.
Any help / clarification gratefully received !
Thanks,
Mark
Life Member
I think that the head light switch should be illuminated at all times. Mine comes on with the ignition and stays on regardless of whether or not I have the lights on.
As far as the flashing buld goes, I only have the led in the dash that flashes with the hazard switch. Nothing else. I take it that your led works as well?
Dan
Ian
'89 Clipper Auto and '92 GTI Cabby
Thanks again,
Mark
