head lights on, power to cluster off?????????
(In Topic #106492)
if this is an earthing issue or a power in put issue which wires should I be looking at behind the cluster?
Not uncommon to have burnt loom wiring causing strange problems .
Start with simple things
Cheers …………..
Although I did find that if i disconnected the gray blue wire on the plug to the head light switch and turned my lights on the dials still got power but there was no illumination to the cluster?
The grey/blue is a variable +12v that goes to the illuminations (i.e panel lights) and works from the adjuster just above the light switch.
~Madferret
Mk1 1457cc 5door GX '83
Might be worth checking this before you start pulling things apart.
83 MK1 1.9TD mars red, T25 TD campervan, 97 sharan-daily drive/work horse/rust bucket
