Head lamp conections Help
(In Topic #134348)
I have had a respray on my cab and the guys put all the trim and sudries back on in the price.
I havejust booked an MOT and thought i had better check everything works. My question is This, When i switch the side lights and main beam on the front spots come on. I am sure this never happen before the respray, and when i switch the fog lights on both clicks only the rear light comes on.
Have they wired up incorrectly as i cn't sus what the have done all conectors seem to be right :?
take it back mate, you paid for it to be done correctly
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
isn't something silly like you have front flasher still activated is it ? when you flash in a mk1 they stay on you have to pull the flasher stalk again to switch them of again ??
just a thought
just a thought
They are a paint shop baggie, i don't think they would be able to sort it now.
Don't think the stalk was back matt, i will check tommorow. I hope it is not a MOT fail, it's going in friday
im in brum on sat, not much use if mot is friday
No Baggie Ty I'm in Kent
inner lamps were sometimes main beam and not fogs fyi. what are the E markings on them?
if you want them to be fogs the front fog connector is up under the header tank, its got a yel/white and brown wire to it. connect the inner lamps to that instead of how they are wired now.
but you need to figure out what type of lamp they are as the light patterns differ for fog and spot units
Thanks for the advice John.
A bit gutted as it failed the MOT on the lights, Emissions and rear shock top mount corrossion. I have sourced as much VAG suspension available to replace front and back. I hope to have a good weekend to sort out the these issues and get it through. It's been two years since i got behind the wheel and i'm itching to get out.
you going to stoor park? i have NOS gen vag rear shocks that i'll be bringing with me forsell
Thanks for the offer Jonny. I have purchased VAG inserts and Boge springs.
Hoping to make Stoner if i get an MOT
bit late it was last weekend
Yeah i checked after posting :redfaced: Been out of the loop for a while, about time i got out to a gig
