Head lamp conections Help
(In Topic #134348)
I havejust booked an MOT and thought i had better check everything works. My question is This, When i switch the side lights and main beam on the front spots come on. I am sure this never happen before the respray, and when i switch the fog lights on both clicks only the rear light comes on.
Have they wired up incorrectly as i cn't sus what the have done all conectors seem to be right :?
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
just a thought
Don't think the stalk was back matt, i will check tommorow. I hope it is not a MOT fail, it's going in friday
if you want them to be fogs the front fog connector is up under the header tank, its got a yel/white and brown wire to it. connect the inner lamps to that instead of how they are wired now.
but you need to figure out what type of lamp they are as the light patterns differ for fog and spot units
A bit gutted as it failed the MOT on the lights, Emissions and rear shock top mount corrossion. I have sourced as much VAG suspension available to replace front and back. I hope to have a good weekend to sort out the these issues and get it through. It's been two years since i got behind the wheel and i'm itching to get out.
Hoping to make Stoner if i get an MOT
