hazard warning lights not working :-((
(In Topic #114839)
my hazard warning lights are not working..
when the switch is flicked nothing happens, the light on the dash lights up permenatley but thats all.. i changed the switch but this didnt change anything..
anyone any ideas????
cheers all
mike
I've checked wires, fuses, replaced relay and switch but still no joy
Wiring loom is actually OK.
Also have a live wire from G7 contact on back of fuse board going nowhere??
Where should it go?
Life Member
it goes to 12
never knew there were more
concunningham said
no fuse 19
it goes to 12
Depends which fuse box your car has, if you read the ''sticky'' at the top of the forum it's all there for you.
Just be aware that the wiring info shown in the ''sticky'' is for the series 2 fuse box.
If you need the info for your car it's all in the haynes
My Hazards are doing the same thing
My switch and Relap seem fine also…..
When I flick the switch the green light just stays on full
