Hazard prob!
(In Topic #73479)
Hazard prob!
All that doesn't work is my hazard warning lights. The indicators themselves are fine, I've fitted the correct fuse needed for hazards, but it blows as soon as I put it in before I even turn the hazards switch on.
Presumably this means a relay problem?
I'm going on a long journey soon, motorways etc, so I'd like the option of having hazards!
Thanks for any help. Lot to learn!
_________________
As the indicators work fine and the fuse is blowing when you turn the hazards on, I'd start by swapping the hazard switch!
I believe the hazards work off the same relay as the indicators - The switch just powers both left and right circuits at the same time, so if your indicators work ok, then I would say that the relay is not at fault…
My Build Thread
Diesel-dubber said
Nice lookin Golf by the way! 8)
Cheers!
My hazard switch is a bit dodgy and needs a good firm action to ensure it works properly. Was going to get rid of it in favour of a toggle switch but it is VERY complicated inside!
My Build Thread
ops: Cheers!
Steve_Matthews said
Yup - they just tuck in under the windscreen rubber surround and sit in the drain channels (got some on my Driver too!)
As he said…
Mine had some thick sponge stick pads on them to help them stay in place, though I don't think these are required. They are a bit of a pain to fit mind you!
My Build Thread
