Guages
(In Topic #154571)
Any info will be much appreciated.
Thanks guys
JMO.
rubjonny said
when you say gauges, you mean the dash cluster right? if so both vdo and motormeter were used it seems random as to which ones you got. try to get vdo the general consensus is they're better than motormeter
Are both sets interchangeable?
Sticker Pig
Now just need to get a pair!!
early mk1 MFA has the big MPG gauge and shift light, later GTI clocks do not. also early GTI just have mfa button on stalk, 1/2 switch is on the clocks. fit late clocks to early car and you wont be able to switch between modes 1 and 2, but everything else will work (loosing the big mpg gauge obviously, but the digital mpg gauge will still work)
if you fit early clocks to later car the mpg gauge and shift light wont work, but everything else will. the 1/2 button on your stalk will no longer work but the one on the clocks will
if you dont have a gti then any set of clocks will do, just the mfa will not work (unless you add the wiring yourself)
Sticker Pig
