Gauges
(In Topic #106295)
Gauges
thanks, joe
Ive seen the guide in the electics section, what im after is a wire-wire guide, etc as im not used to the layout of the mk1 golf yet.
thanks
Life Member
Anyone know what vw/audi to take the double oil pressure switch from, im not going to the stealers. Is there a gsf or euro car part number for one??
1)How do you join the wire to the lighting track, do you cut and spice into the lighting loom, or is there a spare terminal on the lighting track to plug into, either way which wire/terminal did you use??
2)In the above diagram do you earth straight to the battery's negative, or just an earth point (I think just an earth point but the diagram say battery)
3)Have most people connected the gauges to the ignition switch, if so where on the back of the ignition barrel??
Thanks, Joe
read nearly all these threads and to be honest i am more confused now than ever!
Pritchard said
O.K, ive read all the guides, diagrams etc. What I want to know is the following….
Thanks, Joe
I've got the gauges installed in the centre console but haven't wired them up yet. Think I'll possibly do a 'how to' thread if I manage to get them working, can't believe there hasn't been one done by now 8O
With a bit of luck I'll be attempting it in the next few weeks, if time allows. The guy that sold me the gauges kindly 'pre-wired' them for me so hopefully that'll make it a bit easier. From what he told me two wires go into the engine bay - one to the oil pressure sender & one to the temp sender, they also need a feed from the ignition circuit & an earth. Hopefully once I've had a chance to have a look at it I'll have a better idea whats going on, then again maybe not !!
