Fusebox
(In Topic #104936)
Fusebox
I can see that it's hooked on to the metal bracket, but I don't want to force it off that.
1983 Lhasa Green GTI
You turn the key and 12v is sent to the starter solenoid via a small Black wire at the top of it . When it receives this signal it throws a switch and operates the starter , turning the engine over . That's why your starter is connected to the battery via large cables .
If you are not getting the starter to work , is battery flat , are dirty connections at battery / starter causing problem , is ignition switch faulty ? Is starter faulty ?
Don't think this is fuze related
Cheers …………………
