Funny wipers
(In Topic #153862)
rubjonny said
yep and yep. the relay is 19 or 99, the motor swaps over but you will loose the lower mounting point. was never a problem in my cabby. need to cut a length of wire off the donor mk2, then crimp spades on and pop into mk1 loom
And what are the pros ? Just a better motor ?
rubjonny said
yeah its newer so better nick, im not sure if its actually any faster just that all mk1 motors are billions of years old. mk3 golf uses the same motor so they fit as well. if you do go looking for mk3 donors, swipe the 99 variable intermittent wiper relay too for added awesome
what does the the 99 relay do? apart from adding awesomeness aha? what ever that is
rubjonny said
allows you to adjust the interval between the intermittant wipes, very handy
Sorry for all the questions but how would you be able to adjust it ?? Thanks for all the help
if that doesn't help then nip to scrappy and rob a mk2 or mk3 golf wiper motor, be sure to cut off a bit of the loom with plug on it as well. then either splice to mk1 loom, or crimp spades on and push into mk1 plug.
the mk2/3 motor is a direct fit, but is missing the lower mount. it makes no odds though it wont go anwhere! ran my cabrio like that for ages till i sold it on
