Fuel Pump relay
(In Topic #146417)
Fuel Pump relay
it was a 1.1 so it had a manual pump before
what i know so far is that i need to use relay position 2, which goes through fuse position 5 / 15a
and i need wire e14, which i dont have, so when i put a connecter to e14, what wire connects to that ?
also what other wires do i need to connect to what ?
then for the output yes it goes to e/14, you might want to put 2 wires from this 1 running to a male spade the other goes off to your fuel pump. the reason for the 2nd spade is for the g60 ecu loom, you need a fuel pump feed for the injectors and lambda heater. factory ce1 fusebox gets this using a spade plugged into e/14.
then its just a case of run an earth to the fuel pump back to the claw above the fusebox, then you're done!
polevolt does the pins if you have a good crimping tool, otherwise hack up some spare ce1 fusebox plugs
the problem i have is that i am getting absolutely nothing at the fuel wire from the g60 ecu (pin 3, red/yellow)
not power or no switched earth which i find strange,
but i do have all the wires ready to go all crimped up with nice new draper crimping kit
fuel pumps all plumed in, already have the injector / lambda /pump wires joined and connected to e/14
and i have relay 80 ready to plug in
if pin 3 isnt switching to earth then either the ecu isnt powering up or its dead
im pretty sure the one with a built in rev limit is relay number 62
the ecu is firing up alright, cranks over and everything else seems ok
just nothing at all out of pin 3 for the fuel
cheers me deers
