Fuel pump constanly running
(In Topic #97002)
my question to you is, should the relays (specifically the fuel pump relay) on the fusebox be the mk2 16v relay or the mk1 relay?
This by passes the coil pulse feature . In the event of a mishap [accident etc] the pump running all the time could be a safety issue . You can buy various cut off devises try Deamon Tweeks site .
if you look at the pins the colours of the base vary
brown base prime on ignition for 2 secs
white base only prime when cranking
obviously both prime while running
bens_cab said
2 types of relay that fit in the mk1/mk2 fuse box
Sorry to put a spanner in it . Mine is black under and primes pre starting . I have a spare and thats the same . Article in Golf+ maq recently about these relays by 'The Brain' i will try and find it .
Cheers …………
i was on the understanding the pump primes for 2 seconds then kicks in when cranking
bens_cab said
what relays they got are they the brown base ones?
Thats how i understood it should work, exactly like a mk2 16v does.
Primes for 2secs when you switch ignition on, then runs when cranking/running.
Not looked at the base of the relay, but its a 67 relay and is blue, this is what the mk2 16v used.
Chairman
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Chairman
Shed some light please?
Follow us on:
Follow us on:
Chairman
Follow us on:
Follow us on:
