Front Window Wiper Problem
(In Topic #141784)
I am having some problem with my front wipers, they work when the stalk is fully up and the washers also work, but nothing else does. I have changed the relay with a second hand unit (which i think works) and it still doesn't work.
Any help would be great.
Jase
even if neither of these fix the problem you'll have a better wiper motor and variable intermittent when you do so not a waste of money
I remember having to change one as some of the positions where not working.
This bits inside broke preventing the electrical contacts from working.
I don't disagree with the mk2 motor upgrade, I might do that myself one day.
rubjonny
Does the MK2/3 motor bolt straight in on the mk1 mountings on do you have to custom a bracket and then just needs re-wiring?
Malcolm
I have tried three different stalks now, do you happen to have the wiper and stalk wiring diagrams?
Jase
I dont have the wiring diagram electronically, but I am sure the standard Haynes manual for your model should provide the detail.
