flippin horn again grrrr
(In Topic #98839)
drove my car monday after what i thought was problem solved, only to find that yesterday and today the horn is worse then ever. back to square 1 i guess. any suggestions folks. i am going to have to look for a short some where, i did notice that the rubber cap covering the leads to the horn where not on properly i wonder if water has got into them and this is causing the horns to sound? although i can hear the relay clicking on and off. will have a look at the fuze board to see if there is a loose wire. i know if you don't clear the drain holes out water can overflow back into the car and down to the fuse box, but mine is dry, so it could be the relay it's self. if not then iwill have to trace the wires back from the horn ring back to the fuze box, will i have to remove the whole dash to get to the loom?
help guys. :cry:
Life Member
flippin horn
where abouts will the column earth wire be situated? and where does it attatch to, i really am clueless. ops:
hello!
Problem solved ? Fit a relay near the horns if you want 2 working or run just one . If you only have one horn try changing that .
flippin horn again grrr!
Can't help beyond the dodgy contact ring suggestion!
Hope you get it sorted soon! I only had my problem for an afternoon. Got a mate to disconnect the horn for me and drove like that till hubby fixed it.
Mind you, I was alarmed to find that i still had the horn working when I pressed it without thinking. The mate didn't realise that GTIs have two horns and only disconnected one. Luckily it was the one causing the problem - how come it wasn't both though???? :dontknow:
if you do you are tracing a short, if you dont then the steering wheel is the right place to look for the problem.
1988 1.8 carb Golf Clipper
flippin horn grrrrrrrr!
i have now looked at the gap between the wheel and the stalks column contact where the 2 meet each other the gap between them is slightly lower. with the wheel centered,it really compresses the horn column tab down flat. is there any way of spacing the wheel to make the gap slightly wider? to take the pressure off. i think that my column may be bent, this happened before i got the car. looks like it had been stolen before. what happens is the thieves pull down really hard on the wheel and force the steering lock twisting the wheel at the same time, bending the column, so when you turn the wheel it turns concentric.so the gap between the horn contact ring and the stalk base alters when the wheel is turned. i am wondering if this is the problem! will disconnect the horn centre to see if that helps as suggested.
will keep you posted.
flippin horn grrrrrrrrrrrrrrr!
that's my next job to check wheel connections. the problem is the horn works fine and most of the time doesn't go off, but it's like the thing is haunted it does go off on it's own accord without me pressing the horn centre. like Debs said people look at you gone out. Am going to trace the earth wire through the wheel to the rack to make sure there is continuity, like i have said the earth from the column to the rack is ok i have put the multi meter through it and there is good connection, thats where crocodile clips and extra wire comes in handy. i wiggled the wire to see if the connection was intermittent, but it was ok.
had a good look at the fuse box end, i couldn't see any loose plugs etc and i removed the relay to check it, it seems fine and is a snug fit in it's holder.
problem is it's difficult to see what you are doing up side down in the foot well. especially with a broken jaw that's been wired up, at least my Doris can get some peace and quiet.
i also thought about the wheel being slightly off, could this be the column bearings, as i read somewhere that the bearing housing is plastic. Any one care to enlighten me?
cheers folks
flippin horn grrrrrrrrrrrrrrr! hurrah!!!!!!!!!!
thanks to all who contributed.
Started off removing the horn centre, but the horn still went off, next took the wheel off and checked the wires from the wheel, they checked out ok.
so removed the steering column shrouds, as i knew from before the wiring under had some black tape around it. un peeled the tape to see that someone has at some point spliced wiring into the wires that go to the indicator stalks etc, probably for an alarm. i cut out the bad sections and re crimmped all the wires.Someone told me not to solder the wire as the flux contained in the solder attacks the insulation, due to it being acidic? bugger me after all that it still went off.GRRRRRRRRRRRRR!
back to square one.
your right cedar you could build an engine in the time it taken me to sort this out.
well sat there, car in bits, a tear in my eye and a cup of tea, why is tea great, you know "sit down love have a cup of tea and a fag, got some bad news for you, your telly's f……d" funny how i remember the tv repair man breaking the good news to my mum, when i was a kid.
Sorry folks got lost there, so sat there staring, then it hit me, i noticed that the tab that rubs against the horn ring was being pushed down and it was just barely shorting on the bottom screw that holds the indicator/wiper assemblies in place. i had noticed that the screw kept going round and the thread was stripped, so simply removed the screw and placed some insulating tape over the black plastic holder the tab is joined to, covering the metal underneath, then placed a piece of tiny "O ring" rubber under the tab, to help stop it being compressed to much, re assembled every thing and so far so good.
mmmm wonder whats next?
cheers Guy's and Gal's :mrgreen:
flippin horn hurrah
Re: flippin horn grrrrrrrrrrrrrrr! hurrah!!!!!!!!!!
chortle said
well folks i believe i have cracked it.
back to square one.
Just found this post via the search function. THIS IS GOLD It should be in the FAQ.
My horn has been driving me mad going on at random. Checked all wires, but couldn't find the problem. Read the above, ran to the car and checked. That was spot on the problem
Thanks to 'chortle' for providing the solution :notworthy:
Re: flippin horn grrrrrrrr!
chortle said
cheers folks,
You might have a piece of the steering lock jammed somewhere. Remove the wheel and steering lock parts and re-assemble it sorted mine out.
~Madferret
Mk1 1457cc 5door GX '83
back to square one.
Cheers Bud it's nice to see that my strife has helped someone else out. Much head scratching with that one mate, but that is what this site is for any thing to help.
have done a couple of how to's as I now got a decent camera.
1) B pillar replacement (Cabriolet)
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=48305&highlight=pillar
2) my latest attempt Seat refurb should suit both cabby and tin tops
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=59405&highlight=seat+refurb
hope these help.
We used to use Trichloryethene but I think its banned now
~Madferret
Madferret said
Btw solder is better, flux IS acidic but you dont leave the flux on when your done soldering you wash it off with whatever solvent you have to hand, isopropynol is the best and you can get a large bottle from boots.
cheers for that madferret,
I alway's wipe down flux from soldering. Best practice for plumbing too.
But as the flux is in the solder all ready, I was told that the heat from the Iron swells the plastic sleeving and the flux runs under the opened plastic.
I did think that the small amount of residue would be negligble.
Is that correct??
It's hard to know what's correct as people have differing Ideas etc.
