Fixed Alternator Problem
(In Topic #72638)
On returning to my garage after xmas I found that having another look at the engine bay the link harness to the alternator was burnt out/cut in half :idea:
Well went to work yesterday and got the electrical harness guys to make me up a new one, then got a new alternator socket and heat shrinked the thing up.
Put the car back together and it started and ran perfect after being sat for 5 weeks over the xmas period, took it out for a spin and realised how much fun a mk1 really is. Sorry for every doubting it!!!!
Anyway, two things:
1) check your link leads as the guys at work said over time wires do give up, hence causing a breakdown.
2) should there be an earth wire to the alternator?? the Haynes says yes but I don't have any leads in my engine bay. Can someone have a look for me???
Cheers.
'83 Helios Campaign Gti
Beware the "Black Wire Syndrome" !!!!!
'appen one of our brilliant electrickery guys can explain that one, but the (copper) wires just turn black but otherwise look wholesome. In fact they have so much internal resitance that you can hardly drag a single electron through them….they also fall apart when you just look at them…'tis a problem I have to watch out for with my (older) model airyplane battery leads…I disconnect the radio batteries when I'm not going to fly one for a while….'appen suggest that those guys who have their golfs laid up do likewise
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
As far as I know there's no earth wire directly to the alternator, but there is an earth wire that earths the engine to the chassis, and the alternator will in turn be earthed through this as well. Not sure where it is as standard, as I've added it myself on mine as it was missing when I brought the car! How it started I'll never know!
1983 White cabriolet GTi
Good luck with those nasty 'black wires'.
