Fitting heater blower motor.
(In Topic #131046)
Yo.
Was wondering if anyone could advise me on how to fit a new heater blower motor. Mine has packed in
Cheers.
Cheers.
Mk1 Golf 1983 1.5 GX
Are you sure it's the motor that has packed up and not the switch ???? :dontknow:
Thanks chortle
jaycab, I'm pretty certain it's the blower motor. It was working fine then suddenly started making a rumbling noice. It was like a bloody cement mixer. Then it just cut out.
Fuse has blown then fella, common prob, open the bonnet, if the plastic black tray is there pull the clips off and the rubber strip and remove, undo the plastic cage and lubricate where you can, especially the bearings.
replace the fuse and switch on, hopefully it will run if not back to square one lol.
Aah that seems a lot easier then. I'll see to it this weekend. Thanks very much.
another tip is to keep hitting the motor with a hammer, all the crap will fall off and free up the motor. Seems to happen a lot if you don't use the car much.
