Few electrical niggles - Horn and front fogs.
(In Topic #120704)
If anyone has any ideas on how to solve either issue they'd be much appreciated.
Cheers,
Have checked the number 16 fuse (for horn) and that is ok..
Have a read The Mk1 Golf Owners Club
Come to think of it my horn wasn't working when i winter stored mine !
Cheers ………..
Life Member
1. is for the rears
and
2. is for the fronts
Just a thought because I fiddled with my headlamp wash for months (literally) and one night went into the garage with the lights on and spray/wiped the windscreen and the HLW worked - then it dawned on me!!! Dur! :redfaced: But if no one mentions it, you may never know.
Dan
Life Member
had the same problem last year with the cabby electrician had to fit new wiring from the fuse box as no power was going to that fuse from the battery side you would think a horn is simple to power but obviously not in the case of the Mk1…
Dano said
Just a thought on the fogs… you are using the second 'click' on the switch arent you?
1. is for the rears
and
Dan
Had me hoping there - Unfortunately not the case….
Thanks for all the help, seems i'm in for a bit of a struggle - Any ideas what to check first?
Life Member
Relay
Bulbs
Connection
Switch
Power
…. in no particular order, although I'd probably check that you've got power going to them first!!!
Dan
Now for the damn fogs….
Life Member
"As above"!!!
