favor needed please!!
(In Topic #75567)
this cable was cut when i got the vehicle!! but id like to sort it out so anyhelp would be brill :wink:
Life Member
its not an int light as it comes up from by the g/box nr the switch for the mfa???
If it's a cut wire, where does the other end go to?
and its brown and white
andunp said
it starts by the gearbox and (cut) and ends up by the fuse box
Could be for either the reverse-light switch or the 5th-gear switch (MFA), but if these are intact it could be an (unused) foglight wire with the end connector cut off. Does it go into the big black loom cover on its way into the fuse box, or is it "naked" all the way to the bulkhead?
try
