engine teething probs HELP!!
(In Topic #77516)
the keep leaking fuel after the cars stopped and flood the engine, there are posts on here showing how to check injectors are good.
rgds volkswarren
Regards Volkswarren
rgds volkswarren
Regards Volkswarren
adi
low idle on start up could be the aux. air valve on the back of the inlet manifold, not tested mine yet but when you start the car, squeeze the pipe coming out of the valve and the revs should drop and then pick back up when you let the pipe go (if it's working correctly)
