Engine is dying when lights are on
(In Topic #132904)
I need to post in project thread with my mk1 when I get the time
Have a problem at the moment, the engine is a 1.8 16v kr from a mk2
Recently had the engine timing all sorted running a lot smoother and fine but all of a sudden I turn the lights on, and the idle rev goes down at 0.5k revs choking and dies every time. The revs are a lot sharper and drop down a lot quicker. I have to keep reving and left foot brake when stopped, is this an alternator or battery problem? when I drive the engine chuggs a lot like as if im doing 10mph in 5th gear when im actually doing 50
Help appreciated, thanks
Stevo.
Web Team
Stevo.
Its a bit of an odd problem though, even if this was occurring, the engine should cope with full alternator output required while more/less idling. What controls idle speed on your 16V, there's a few different ways to arrange things (either use the AAV of the Mk1 GTI, or transfer the module and ISV etc).
It only started to happen when i took it psi tuning to get the engine setup tuned. I'm not to sure I know it has a k jet fuel system
Stevo.
Stevo.
Also get them to check the volt meter at the battery and what voltage the alternator is kicking out. This is because I had a really bad contact at the starter motor, all the connections were really corroded and the alternator was dropping all its voltage on that connection.
Do you have any problems starting your car?
06 Audi A3 (Wifes daily)
