Electric window switches for an electric life kit ?
(In Topic #141081)
The motors only have 2 connections so I assume that means that positive on one end and negative on the other depending which way you want the motors to go ?
Is it going to be necessary to get a 'comfort module' or other offboard box to make it happen or can I just use a few of the relays I've acquired from scrapyards over the years (will the 4 pin relays (30, 85, 86, 87) work or am I going to need five pin (30, 85, 86, 87, 87a) relay please) to do the job ?
From the other threads - This seems to be the most useful link I found, but any further help would be much appreciated.
If you want 1 touch control like the cabbys then you will need a control box etc etc
Otherwise just a positive and and an earth
i might have some suitable switches actually, will have a look later
Not to worry I'll cut some slots in the dash / centre console for them. All I care about at this point is having electric windows.
I noticed that in some of the other threads that you said you had an electric life kit too, you wouldn't happen to have a wiring diagram for it (switch pins and all) would you please ?
EL kit:
Google Sites: Sign-in
you should definitely add a relay as you can blow fuses if you just take it off an ign live feed (ask me how i know!)
factory mk2 wiring for leccy windows is basically the same, see my sig for jetta89.pdf which will show you how to do it the factory way on a later mk1 golf blade fusebox
