dashboard lighting
(In Topic #75335)
Guest user
dashboard lighting
Whilst driving home the other night i noticed that i have very few reamining working interior lights :cry: , what i'm on about are the ones that go behind the dash switches and ashtray. Luckily the lights on my dash dials are working well! 8)
Does anyone know where i can get these interior dash replacement bulbs from?
Will
Mk1Gti1600 said
The bulbs in the fog light and rear heated window switch are not replaceable as far as i know :? the ashtray buld is a small capless bulb which you can buy from any car shop mate
The bulbs in the fog and heated rear window are replaceable - they're a teeny little push in 1.2W bulb, same as used in the handbrake light, headlamp switch and hazard warning switch. And some VDO gauges.
There is a bulb that illuminates the heater/ventilation controls too. So I think that's 5 - cigar lighter, ventilation, 3x in the dash pod.
Guest user
cheers for the reply, any idea where i can get hold of the bulbs?
:dontknow:
Will
The bulb behind the heater controls is in a holder that I think you can only get from VW. The OE bulb holder is an all-in-one unit that you can't remove the bulb from. You can remove the bulb in the VW replacement part. I think the bulb holder for the ashtray bulb is similar.
The bulb holder in the fog lamp switch (I think….memory not what it used to be) is another all in one unit, as is the VW replacement part.
The bulbs behind the speedo are slot in ones you can get from Halfrauds.
You can get 2.3W bulbs, instead of 1.2w bulbs (same size and fitting) for some of these. However - I've found that fitting a 2.3w bulb behind my heater panel has resulted in a melted bulb socket So I'm planning to replace this with a 1.2w, even though this will make the panel less bright. here are the bulb numbers, although when I presented these to VW I got a LOT of 1.2w bulbs, and no 2.3w bulbs, so probably best to get the bulbs you can from Halford (and be prepared for meltdown), and the holders/other bulbs from VW;
Instrument cluster
431919040 bulb w/ black base 2w x2
431919040A bulb w/ white base 2w x1
Heater panel
321919039 socket for bulb x 1
N0172512 Bulb 2w x1
Handbrake indicator
N0172512 Bulb 2w x2
Cig Lighter
171919244A Socket for bulb x 1
N0172512 Bulb 2w x1
Headlamp switch
N0172512 Bulb 2w x1
Hazard Switch
141957397A Socket for bulb x 1
N0172512 Bulb 2w x1
Rear window heater switch
N0172512 Bulb 2w x1
Fog light switch
N0172512 Bulb 2w x1
Oh - and it's not difficult changing the bulbs. Just make sure you have a separate pot for dead bulbs, and live bulbs :wink:
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Guest user
Many thanks
Will
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=629&postdays=0&postorder=asc&start=20
