dash
(In Topic #102287)
dash
Hi Scott this has been answered loads of times, use the search function above and you'll get the answer quicker.
Anyway, if you stand in front of your car with the bonnet open on the rear passenger side corner of the rocker cover there should be a wire (usually brown) that attaches to the corner nut. This is a fuse for the dash and runs the rev counter. Re-connect this wire (it will probably be hanging down the back of the engine) and all will work.
If you can't find the wire then there is a wiring diagram for how to create a new fuse wire somewhere in the search.
HTH
