damn car
(In Topic #100624)
Guest user
damn car
but why on earth do my hazard lights work, and when i put the indicators on, does the green light glow green (not flashing) and the indicators dont work??
the bulbs flash on hazards but not indicating???
and still my light switch and full beam adjust the rev counter i.e. lights on rev counter and clock off.
suppose atleast the engine temp is working i think again.
What the heck is going on, all I did was change the inner dash!!!
and im not keen on driving without indicators.
help appreciated, please speak in basic terms.
keep on topic and dont take the mickey
This problem has always been related to a faulty Hazard switch . So my advice is to ……………Try a new relay and a new hazard switch . The hazard switch is ?10.72 from VW
Quite why you should be having these problems i don't no :dontknow: There is a related post to your problem here http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=44356
Cheers ………..
Guest user
the hazard switch worked fine yesterday and today is it linked to the indicatrors then?
Guest user
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=35549
Guest user
Tried playing with the hazard switch no joy.
Right here goes, now i've calmed down a bit, had a bad day this is exaclty what is happening.
1. When the lights are on ( not turning key or putting ignition on ) the light dimmer switch works, and illimuniates the dash to the desired level however….
Switch the keys onto ignition or start her up and it goes all black
2. The little green light where the indicator led thing is is on a constant low green colour
3. put the lights on full beam and the clock goes out, and the rev counter goes off, and this happens when you play with the light adjuster too!
4. There appears to be no water in the fuse box all fuses are ok
I dont know how to fix a relay, dont know if its broken or not.
Why on earth my car has suddenly decided to go stupid i do not know.
Im not an expert never confess to be, but its REALLY REALLY ANNOYING ME NOW.
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
like Jamie said above it's the clock earth that causes the rev counter to die when you turn your lights on. An easy check is open your bonnet and look at the rear corner or the rocker cover. There should be a brown wire connecting to the corner nut on the rocker cover. This is the clock earth. If this isn't connected do it and it should solve many of your problems.
Guest user
but hey atleast i have lights, indicarotrs and wipers, heated windows and fog lights lol
this happend to me before where my green light wud come on and stay on. hazards would work but indicators wudnt.
turned out to be a fuse..
it kept blowing so i put a 15 amp one in instead of 10.
never had a problem since..
93' cab in need of a miracle
Guest user
Guest user
GRRRRRRRRRRRRRR GRRRRRRRRRRRRR GRRRRRRRRRRRRRRR get me a hammer im going to start hitting things!!!!
Similar problem
