coil signal
(In Topic #125712)
coil signal
just a quick one, after doing a efi, digifant conversion from a mk2 golf into my 89 gti cabby i cant find a spark. it seems iv got no signal at the hall effect of coil? :dontknow: everything up top in the bay seems to pin out exactly as it should according to the haynes wiring diagrams, we used the mk2 engine loom and fuesbox. i have a red+black wire that goes from the coil to pin 26 connector d in the fuesbox. i was wondering if anybody could shed some light on where the fuesbox takes it from there?
thanks in advance, liam.
If you turn the ignition on is the wire live at coil?
I'm thinking this is the power source for the coil.
Have you used the dizzy, coil, ecu, and the TCI module from the donor?
thaks liam.
~Madferret
Mk1 1457cc 5door GX '83
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
