Coil mistery wire !
(In Topic #122394)
Coil mistery wire !
its a black wire connected to the terminal on the far side of the ignition coil next to the bulk head ( furthest from the front o the car). but the other end is not connected and has a spade connector on it ??
It is coming from the terminal with another black wire which goes back through the bulk head to the cabin.
any ideas where it should go ??
How many wires does the coil have coming off it that do go somewhere?
What colour are the wires?
Green goes to - Negative side
Black goes to the + Positive side
Lilac/White goes to the + Positive side to Pin C15 on series1 fuse box (Pre <1983) Pin D15 on series2 fusebox(Post 1983<)
so someone could have used it to run a relay or whatever for an additional circuit.
If your car runs fine and what not without it dont worry
<a> <img></a>
this was a small bit that I though might have something to do with my starter motor "running slow" sort of turns over slower than I expect, I have check and cleaned the main earth I was just worried that this should be connected some where.
S
S
Driver driver.
