clock /rev counter
(In Topic #121615)
clock /rev counter
my clock /rev counter is doing wot it feels like doing lights coming on wenthey should not needle on rev counter doing the same .i think it may be a bad earth but not sure is this a common fault thanks pete
I had the same issue over the weekend. I removed all instrument switches, clocks and dash insert. Checked the two wiring looms which plug into the clocks. You have one small one which plugs into the left hand side of the clocks which controls your MFA and one longer one which plugs into the right hand side of your clocks. The small brown wire within these looms is the earth wire, mine was loose so I pulled the cable out and pushed the metal prongs up and cleaned the connections on the back of the clocks. I did the same with all connections and wires in the loom. Now I have all lights working MFA rev counter etc…
See below illustration which might help:
clock/ rev counter
hi mate thank you for repling to my message i did what you said stripped it all down now working fine . you dont no how much of a headache it was giving me very much apprieceted thank you
pe
te
pe
te
