changing millage reading on speedo.
(In Topic #132140)
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
Basically, you take the clocks apart and rearrange the numbers, then put it back together. A set of jeweller's screwdrivers would be a good investment, and also give a good clean up while you're in there.
And no, doing a "Ferris Bueler", mounting it on bricks and running it with a brick on the throttle in reverse doesn't do it (quick enough). Also winding it back with a power drill is a bit slow.
Of course, only if you have a legitimate reason to, such as replacing the clocks with another set and adjusting the new ones to true car mileage.
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
