Car will not start
(In Topic #125271)
Car will not start
what you need is a k-jet relay, gsf sell the one you want:
935VG0090 k-jet relay without limiter £ 23.20
to prove this either way, swap your 53 relay into the fuel pump socket. this will make the fuel pump come on with the ignition. its not safe to run it this way as it wont cut out the pump in a crash, but it'll get you motoring till the relay turns up
edit: oh and the 53 relay is for the horn, so bear that in mind if you do decide to drive it like that
