buzzing and...
(In Topic #75146)
buzzing and...
Hi all,
got a buzzing coming from the dash, had a look and cant see where it is coming from. giving the dash a whack stops it but starts again. up goes the stereo
Clocks stoped working, miles that is. rev counter, speed all ok.
any ideas on the above?
Tucker
Tucker
the buzzing is the oil pressure warning buzzer, seams to be a regular proble with the dash can be poor earth or connections, I had my car a month it did it once when i had the fan running, switch it off, the buzzer stopped.
It may be that you don't have good oil pressure though!!
Electrics seem to be a pain, but cleaning contacts first can reslove many issues, before you resort to major surgery
Audi A4 1.9TDI - Gone
From the user manual states that the buzzer only comes on if engine speeds are over 2000rpm and the oil light is also on.
comes on when she wants to. just got the car and the guy said that he thought it was the oil presure switch. hes changed it for 3 differant ones and disconected it and it still does it. no lights when going off but some times my oil light does come on but then off again. its a 1500 GL.
hit the dash and turns off :dontknow:
Tucker
Tucker
Sounds like bad earth or connection if it's erratic, and I've never seen low oil pressure cured by hitting the dash
Have noticed a slight oil leak, would that make a differance?
How do i go about earthing it, and where is the buzzer located?
Tucker
Tucker
The oil leak would not generally cause low presure a few drips are nothing to worry about. Oil pressure is created by the pump pushing oil through the crank oil ways to the bearings, low oil pressure indicates a poor oil pump or warn crank bearings (which may cause the engine to rumble) There is a brown/white wire that should be connected to the rocker cover and were the body earth strap is aslo connected, check these first.
Hope that all make sense
The buzzer is in the dash
Rob ;o)
Rob ;o)
So need to check the earths in the engine bay and not the clocks?
I know its in the dash had it all out, cant find the fooking thing as it only goes off when i drive. every time i put my hand in it goes off
engine pulls strong, apart from running rich :roll:
Tucker
Tucker
all sorted and is a dream
Got some clocks from a citi in a scrappy down the road, only 64k on them. good as new 8) few other bits too for 25 notes
Tucker
Tucker
